91 civic bswap issues
Old Sep 14, 2021 | 02:03 PM
Thatsmyciv's Avatar
Default 91 civic bswap issues
Hopefully someone can give me a hand. I have a 91 civic LX that I did an auto to manual and b18 swap to I stayed obd0 since I already had most of the parts car originally started ran a few moments and died due to code 3 (ckp) and 4 (map) after 3 ebay distributors with no luck I got one from autozone and it starts and runs but I still have the same codes and it will not go over 3500rpm. My exhaust does not have a spot for a O2 sensor and is currently only header downpipe could no 02 be causing the ckp issues? Thinking map is bad as car had no change when I disconnected it or is there another way for me to test it?
Old Sep 17, 2021 | 09:02 AM
Thatsmyciv's Avatar
Default Re: 91 civic bswap issues
Did honda-tech die?
Old Sep 17, 2021 | 03:21 PM
Ryanthegreat1's Avatar
Are you clearing the codes between tests?
A bad map will cause the limp mode. With no map you can't compute density in the speed density system.
Old Sep 17, 2021 | 03:27 PM
Thatsmyciv's Avatar
Yes the codes do not show until it is running either.
I am waiting on a new map now so hopefully not much longer there
Old Sep 17, 2021 | 03:53 PM
I assume an obd0 b series harness was used?
Old Sep 17, 2021 | 03:59 PM
Thatsmyciv's Avatar
No I modified my harness
Old Sep 17, 2021 | 04:31 PM
Might start with reviewing your harness modification if the map sensor doesn't fix that code. Could also be you CKP error.
Old Sep 17, 2021 | 04:35 PM
Thatsmyciv's Avatar
I have gone over my modifications and all seem good nothing loose or disconnected I'll see if I can find the info I used
Old Sep 17, 2021 | 04:37 PM
CKP wiring needs to be shielded all the way back to the ECU and the shield needs to be grounded.
Old Sep 17, 2021 | 04:41 PM
Thatsmyciv's Avatar
That could be my problem I wasn't aware they needed to be shielded and shield grounded I'll see what I can find for shielded wire. How do I ground the shield?
Old Sep 17, 2021 | 04:51 PM
Shield is usually grounded to the sensor ground at the ECU side but my memory is a little fuzzy on the older stuff. I have an ETM I can look at later.
Old Sep 17, 2021 | 04:56 PM
Thatsmyciv's Avatar
Would I be able to ground it at any ground point as long as it's solid and bare? Or does it need to go there? Thank you for your help
Old Sep 17, 2021 | 07:19 PM
Old Sep 17, 2021 | 07:20 PM
Found a quick pic on the internet. Looks like the shield gets grounded to G101, I believe that is the thermostat housing ground.
Old Sep 17, 2021 | 07:25 PM
Old Sep 17, 2021 | 07:38 PM
Thatsmyciv's Avatar
So if I swap the ecu pins to the shielded wire put those to the clips at dizzy and ground the shielding to the thermostat housing it should be golden?
Old Sep 17, 2021 | 07:43 PM
Thatsmyciv's Avatar
Also I cut the shielded wire from an old all stock harness pulled from a previous scrap car and the shield was soldered to a wire that was ran to ground will that be alright here?
Old Sep 18, 2021 | 06:46 AM
Perfect on the salvaged harness idea. That was probably a CKP harness.
Old Sep 18, 2021 | 08:06 AM
Thatsmyciv's Avatar
Awesome thank you again for your help hopefully I can get it done today. I'll be sure to let you know
Old Sep 19, 2021 | 04:31 PM
Thatsmyciv's Avatar
Got it changed over to shielded wire from dizzy to ecu and grounded at thermostat housing with no change haven't had a chance to change map as it started raining
Old Sep 19, 2021 | 05:03 PM
Now the expensive option. Find a good OEM distributor.
Old Sep 19, 2021 | 05:05 PM
Thatsmyciv's Avatar
I just spent almost 300 at AutoZone for this one where else should I go?
Old Sep 19, 2021 | 06:04 PM
Is it a stock ECU? Ever had the capacitors replaced?
Old Sep 19, 2021 | 06:16 PM
Thatsmyciv's Avatar
It is a stock pr4 ecu I've never had capacitors tested but a friend of a friend threw it into his ef bswap and it ran it fine with no codes
Old Sep 19, 2021 | 06:27 PM
Borrow a known good distributor?
