B series - 1 pin/stud water temp sensor plug
Old Sep 13, 2021 | 10:19 AM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Default B series - 1 pin/stud water temp sensor plug
Having trouble finding this replacement part, the connector that goes to the water temp sensor in the head, near the water neck. The connector cracked and so I need a new replacement. I did find these online which appear to work in some applications even the k series, which is interesting because they are for American cars.
Essentially what is needed is shown below, the water temp sensor for b series looks similar to that of the k series shown below. The connector is just a simple push on cylindrical style, there is no retaining clip.
If anybody has any ideas or knows the oem part number please let me know thanks! If I can’t figure it out I’ll probably pick up the 90 degree style boot connector that is shown below, one user reported this style worked for their k series.
Old Sep 13, 2021 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B series - 1 pin/stud water temp sensor plug
The factory OE Honda part number is: 37750-PH2-014
Old Sep 14, 2021 | 07:58 AM
spAdam's Avatar
Loved
Community Favorite
It's a 4mm Bullet. These are what I use.
Old Sep 14, 2021 | 07:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Sorry OP... apparently I didn't read your original post thoroughly... I thought you were looking for the sensor part number, but you NEED the connector for the tip of the sensor. This cannot be purchased from Honda, but spAdam had posted an excellent suggestion above. Good Luck.
Old Sep 14, 2021 | 10:11 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Thanks guys!!!
The part I ordered worked, here’s the new and old. Didn’t know the size, just guessed and ordered this and it fits.
ZootownEG
Engine Machining & Assembly
Jun 5, 2019 11:44 AM
mikej94civex
May 15, 2010 07:42 PM
ALL MOTOR EM2
Feb 17, 2007 04:40 PM
1hottEG6
May 6, 2002 02:53 AM
