Dipstick showing above full mark even I only poured 3.3 liters
Hi
hope everyone is doing well. My car civic 2000 with D15Z6 engine which has a capacity of 3.3 liter with oil filter change. I poured exactly 3.3 liters but the dipstick shows higher as you can see in the picture. Can someone confirm the length lf their dipstick? And is the dipstick different for different D Series Engine?
Also suggest should I follow the capacity or the dipstick?
Re: Dipstick showing above full mark even I only poured 3.3 liters
Let the oil settle for a few hours or over night then check it, if its still too high drain a little till the oil is right under the top hole. In the middle is acceptable but i like to keep it right at the top hole.
