Running on three cylinders
Old Sep 5, 2021 | 10:38 AM
gruuvnn.cb7's Avatar
Default Running on three cylinders
Hello everyone, I seem to have a misfire every time I start my car in the morning, sounds like it only runs on three cylinders. This will continue until I am onto the freeway and the car is well into operating temperature. A couple of weeks ago I did a compression test and the numbers were fine for the mileage on my motor, which is 341 k. Which brings me away from the possibility of a dead cylinder. Any tips?
Old Sep 5, 2021 | 10:43 AM
Default Re: Running on three cylinders
These are my compression test results for reference, top numbers are the dry test.
160 150 155 155
175 162 172 170
Old Sep 6, 2021 | 09:44 AM
NVturbo's Avatar
O.G. triple O.G.
have you changed out the spark plugs and wires??
Old Sep 6, 2021 | 10:05 AM
Spark plugs have been checked, look fine, tested the wires using a timing light, consistent flashing through all 4 cylinders, I also checked the distributor cap for corrosion, there was minor corrosion but I cleaned it up with a wire brush.
Old Sep 7, 2021 | 04:20 AM
angrysmileyface's Avatar
Have you checked the coil in the distributor/externally? A weak coil has the ability to cause a miss.
Old Sep 7, 2021 | 09:19 AM
GhostAccord's Avatar
When was the last time you had the valve clearances checked?
niterider96cord
Jun 22, 2010 07:46 PM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
CRX888
Mar 4, 2009 09:26 AM
Chubz
Jun 27, 2002 05:18 PM
Chubz
Jun 27, 2002 02:00 PM
