Civic ek drivers side power window problem
Old Aug 31, 2021 | 09:18 PM
lyfjerry131's Avatar
Default Civic ek drivers side power window problem
Hello guys I’m new to this website please help me out here, I have a civic ek hatch with power window conversion complete, both window works fine before but now suddenly right hand side window don’t work “properly” it will only go up and down if I open my door wide, it won’t work when I close my door while I’m inside. What could be the problem here?
Old Sep 1, 2021 | 05:44 AM
bumpstick's Avatar
Default Re: Civic ek drivers side power window problem
Probably broken wires at the connector. Very common problem. You can pull off the rubber boot and disconnect the connector to inspect the wires. They like to break right at the pins from all the opening/closing of the door. I do believe there is/was a Honda part number for a repair kit that has new pins/pigtails. You could also salvage the pins/wires from the junkyard and have a go at splicing them back together. The door harness is pretty easily replaceable but the car side harness is not.
MurtazaDSM
Jun 17, 2009 10:02 PM
amunoz712
Feb 25, 2009 07:56 PM
fasthcrx
May 9, 2008 05:18 PM
MIKE_HWD
Oct 23, 2007 08:07 PM
lp3kr
15
Apr 1, 2002 11:16 PM
