Ignition timing affect acceleration?
Old Aug 24, 2021 | 06:21 PM
D16Yate's Avatar
Default Ignition timing affect acceleration?
I just got a 98 civic ex with 200k that is completely bone stock everything.
I wanted to check the ignition timing to make sure it was set right (previous owner replaced distributor themselves)
This was my first time doing this and I’m second guessing if I adjusted it properly. It was off before the adjustment but not by much.
After the adjustment, it seems to have a lot better acceleration up to around 4000 rpms then it seems to slow down a bit and maybe get a little peppier around 5000 rpms. It feels like at higher rpms the exhaust is causing a restriction (best way I can describe it)
Is this normal for this engine when the ignition timing is properly set or should it be the opposite (slower until higher rpms)?
Old Aug 25, 2021 | 08:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Ignition timing affect acceleration?
See if you can find any dyno charts for your stock engine. You might see a small dip in torque/power in the graph. That would indicate the behavior you describe. That may be the easiest way for you to confirm your question.
Old Aug 26, 2021 | 05:13 AM
D16Yate's Avatar
Good idea. Couldn’t find one for a completely stock setup I’ll keep searching.
Curious, how crucial is it to stand directly above the timing mark that looks like a V when setting timing? Can you look from different angles or does it skew it?
Is it best to have no lights on except for the timing light to see the markings better?
Old Aug 26, 2021 | 08:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It can be skewed by not having the pointer in the V. And you can be a tiny bit off on ignition timing and you won't really notice much difference.
I had to retard one of my engines to stop pinging due to a thinner head gasket. The car didn't seem very much different in behavior but I knew it was down a little bit of power overall because of it. Engine ran just fine.
Advanced ignition timing can cause pinging (detonation) and that can be very detrimental. It usually takes a fair amount of advance or retard to make a noticeable impact.
Old Aug 27, 2021 | 06:49 AM
D16Yate's Avatar
I noticed there’s two “pointers” does it matter which one is used?
Or do you need to line up the bottom one between the top V?
Old Aug 29, 2021 | 09:18 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The "two pointers" is the system used like a gun sight. The V is the upper mark that you want the bottom point in between for your line of sight. Then you adjust so the red mark lands in that line of sight.
Do you see how in the illustration the V, the pointer and the red mark are all in line if you were looking down birds eye view? That's precisely how you set ignition timing with your basic timing light once that car is fully warm (at operating temperature).
Old Aug 29, 2021 | 10:49 AM
D16Yate's Avatar
Yes thanks. Couldn’t find any info anywhere about lining up the two pointers. Everything I read/watched referenced only using the V.
It’s a little hard to line the two pointers from straight above. The power steering hose skews it but I’ll try again thanks
Old Aug 30, 2021 | 11:38 AM
D16Yate's Avatar
Had to use one eye and awkward angles but was able to line up the bottom pointer between the V during adjustment.
Got it to factory specs at 12* but I didn’t like how the car drove honestly. So I advanced it slightly to the left line of the 3 on the crank pulley (10 degrees?)
Seems to pull better now and has better throttle response. Think I’ll leave it like this.
Honda says to adjust to 12* +/- 2* so I’m technically within spec, but I’m wondering should I start using a higher grade gas or should be good with regular still?
Old Aug 30, 2021 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you "advanced" the timing to line up with the left of the three marks with the center one being red, then you are set at 14* and not 10*. If you are over timed, you may hear knock and will need to increase the octane of your fuel to eliminate it... or retard the ignition timing again until the knock abates.
Old Sep 1, 2021 | 06:29 AM
D16Yate's Avatar
Does the D16Y8 have a knock sensor? Don’t hear any knocking but curious if I should still go to next octane fuel just in case
Old Sep 1, 2021 | 07:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It couldn't hurt... move to a higher octane and send it.
aavtec
Apr 7, 2013 05:48 AM
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
jdmb16ef8
10
May 4, 2008 04:47 AM
CRXLST
Oct 28, 2004 07:52 AM
the.hamburglar
Apr 18, 2004 07:49 AM
