Is it ok to change my Compressor wheel?
I want to put a bigger front wheel and housing on my turbo,
Can I just remove the old wheel and housing and put the new one on and be fine? Or is there something else needed to do this.
It's a t04e 50 front turbo and I'm changing it to a Gt30 front wheel and housing
I dont see it working... Better bet would be to get a t3/t04e 60trim compressor wheel and compressor cover.
Usually you will need a need compressor housing and the correct size back plate. Also i believe the turbine wheel shaft will be different from a t3 turbine wheel to a gt30 turbine wheel.
If it fits will I have to balance back the turbo or it will be fine?
wantboost
Jul 15, 2013 06:18 AM
booscivic
Sep 25, 2006 07:50 PM
AndyFloyd
Sep 16, 2006 01:30 PM
80884
Dec 28, 2005 04:33 PM
elpiar
Aug 8, 2005 06:51 AM
