Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
05 odyssey touring 5 speed swap
Old Aug 20, 2021 | 08:29 AM
Odyssey weirdo's Avatar
Default 05 odyssey touring 5 speed swap
So I am trying to plan out upgrades to my Honda Odyssey and I am wanting to do a manual swap the thing is I also want to make it awd/4wd so are there any suggestions for a good tranny to use I would also be ok doing fab work so I am not sacred to have to cut it up
Old Aug 20, 2021 | 08:43 AM
Ryanthegreat1's Avatar
Default Re: 05 odyssey touring 5 speed swap
05, so the 3.5 V6?
Probably looking at Honda Pilot/Acura MDX parts to make that work. That is a very similar platform.
To get a manual transmission you are looking for a TL SH-AWD. Best of luck those are rare and expensive.
Old Aug 20, 2021 | 02:01 PM
Originally Posted by Ryanthegreat1
05, so the 3.5 V6?
I actually looked at some and there are a lot that have been getting parted out of some ones in wrecks(images show no signs of damage on most listings) for about 500 so maybe there is hope
Old Aug 21, 2021 | 06:42 AM
Could go to the 3.7 and the 6 speed auto with the SH-AWD system out of the 08-13 MDX. Then the whole drivetrain matches and the PCM would be mostly happy. Probably still be upset about no communication to VSA/ABS and a few other modules. Nothing a little CAN hacking can't fix. 305 hp is pretty healthy and the 6 speed auto is hard to argue with.
Old Aug 21, 2021 | 07:52 AM
Well the current idea is disable VCM install a rear mounted turbo for the sleeper look in the engine bay and then lifting it and throwing on some more aggressive tires and of course AWD and manual tranny and really I would just manually control the current one and use pilot AWD parts but I worry about the current one blowing with 300+HP
Old Aug 21, 2021 | 09:03 AM
It is the torque that kills transmissions. No idea what that limit is, not many people are putting the coals to a V6 auto tranny.
Going to a standalone ECU then? Not much support for tuning the factory V6 PCMs.
Old Aug 21, 2021 | 12:43 PM
well the plan is to see if I can reprogram the ECU so I know what I need to do I should be able too though but I will install a vcm because that causes issues but that generation of van has tranny issues and I don't want to blow it while I am driving down a road and I want a manual and will be easier to just replace it with a manual
Old Aug 21, 2021 | 08:16 PM
TL and Accord V6 both have some support from Hondata but be warned, they do not support engine swaps. You will be on your own to make it work correctly.
Same goes for Ktuner, some V6 support but nothing on the Odyssey PCM. Would be a swap in an Accord, TL, MDX PCM and then making it talk to the rest of your body.
V6 support is rather poor.
Old Dec 14, 2021 | 07:27 AM
lothian's Avatar
Beaver's Honda Salvage -- A hey-yooge yard filled with nothing but Hondas! They have that transmission.
low430
Feb 1, 2009 10:39 PM
boosted ek
Nov 19, 2005 12:47 PM
99teggsr
Dec 4, 2003 10:31 AM
OldSchoolHatch
11
Oct 11, 2002 09:13 AM
