Cold weather car problems
Old Nov 17, 2002 | 06:19 AM
mattcxb18's Avatar
Default Cold weather car problems
My car will not start in the mornings when it is cold out? I am a FL boy so i usually don't have to deal with this. Is it just a matter of ......?
You have to understand usually the temp is not below 75...Thanks for the help.
[Modified by mattcxb18, 2:44 PM 11/17/2002]
[Modified by mattcxb18, 2:57 PM 11/17/2002]
Old Nov 17, 2002 | 07:31 AM
rainmanEK's Avatar
big strong guy
Default Re: Cold weather car problems (mattcxb18)
What excatly is it doing? I am also a "florida boy" My friends nor I seem to experince any problems!
I also highly doubt it The kind of coolent/anti-frezz you are using!
First things i would check are tune up items, ie.. plugs, wires, cap, rotor, etc....
It may not be getting fuel, so check for that!!
good luck, eric
Old Nov 17, 2002 | 07:42 AM
mattcxb18's Avatar
Default Re: Cold weather car problems (rainmanEK)
it will start, rev, then die... If I do it about 10 times, the motor will heat up enough to run. It is not even that cold out 50s-60s
Once it is warmed up, she runs like a kitten.
Old Nov 17, 2002 | 07:44 AM
mattcxb18's Avatar
never had a problem till these cold fronts came thru.
other days it is perfect.
Old Nov 17, 2002 | 08:19 AM
mattcxb18's Avatar
ttt
Old Nov 17, 2002 | 08:38 AM
mantic6t9's Avatar
Kinda sounds like a fuel problem.
Old Nov 17, 2002 | 08:44 AM
mattcxb18's Avatar
Default Re: Cold weather car problems (mantic6t9)
ttt
Old Nov 17, 2002 | 09:39 AM
mattcxb18's Avatar
battery is good, it is getting fuel(i think) why would cold effect fuel? First few starts= it will rev to 3-4 k then die. Next few starts to 5-6 then die. Then heat ups and fine. Darn this cold weather.
Old Nov 17, 2002 | 10:06 AM
Neptune's Avatar
My car starts after a few trys and then it revs at like 2k rpm. ONly in cold weather.
Old Nov 17, 2002 | 04:27 PM
mattcxb18's Avatar
Default Re: Cold weather car problems (AmericanWagoner)
ttt
dcivic91
May 8, 2020 06:22 PM
Roland Painter
K Series
Jul 27, 2015 04:25 PM
JDMlyfestyle
11
Dec 24, 2004 10:03 PM
ntt
Feb 1, 2004 09:41 PM
