2000 em1, all factory, only replaced short blk w B18c1. P1335 error? Ecu needed?
Old Aug 15, 2021 | 10:51 AM
02rc51's Avatar
Default 2000 em1, all factory, only replaced short blk w B18c1. P1335 error? Ecu needed?
I have a 2000 Honda Civic SIEM1 everything is original but replaced the short block with a B 18 C1, currently have the OEMECU and acquired a P 73 GSR manual ECU vehicle will not start with the ECU not sure if it has a immobilizer but it sounds like the fuel pump is not activating?
Need help on options to get it running a no CEL.
Smog is needed to register it.
Currently displays p001335 o2 shows lean
Factory EM1 ecu on hand
Factory 96-99 GSR ecu on hand.
any advice?
starter immobilizer removal soldering or is a another ecu needed?
thanks guys!
Old Aug 15, 2021 | 10:52 AM
02rc51's Avatar
Default Re: 2000 em1, all factory, only replaced short blk w B18c1. P1335 error? Ecu needed?
Oh sorry. Runs lean on the factory em1 ecu
does not start off the gsr ecu.
Old Aug 17, 2021 | 01:16 PM
tony_2018's Avatar
Fish Twig
Since you can't identify what ecu you have, take a pic.
Old Aug 21, 2021 | 03:47 AM
WAUKEENEM1's Avatar
Since 99-00 em1 is obd2b, you'd need a 00-01 P73 GSR ecu.
96-99 gsr still obd2a...or you can get an obd2b to obda adapter to run your current gsr ecu.
Old Aug 21, 2021 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
A P73 ECU is NOT for a GSR... it is for a Type R. The GSR ECU identifier is actually P72. An '00-01 P72 OBD-2B GSR ECU will not start in your chassis because it has an immobilizer and your chassis doesn't. A '96-99 P72 ECU will crank the car, but you will need an OBD-2B -> OBD-2A adapter harness. Even if you bypass the immobilizer in the '00-01 P72 ECU, the programming will be looking for the IAB dual plane intake manifold solenoid... which you don't have, so you will get a CEL. A P73 might be better because it is functionally similar to the B16A, however, it will still be too rich. Ideally, you will need a tuneable engine management system, like a Hondata S300, to make it run right. This will require an OBD-1 VTEC ECU and a conversion harness to go from OBD-2B -> OBD-1.
To pass smog, I suggest you try a '97-98 P73 ECU... then switch back to the Hondata tune after you pass.
Old Aug 24, 2021 | 11:50 PM
02rc51's Avatar
Thanks guys. I appreciate the responses.
i do have a P72 GSR ecu that has the immobilzer defeat soldered at 3 places on hand….Still just cranks.
I have replaced the original p2T B16a2 ecu back in the car. I will attempt to try a set of GSR OBD2 injectors as someone else recommended since the flow rate of the gsr is higher than the em1.
just a shot in the dark. We’ll see if it kicks a code after 45-50miles of driving or if the lean prob is cured. If no CEL appears, I’ll run and smog it and still hunt for a type r ecu or chip P28 w Honda data like most recommended. It’s pricey but I guess you got to pay to play right?
Thanks again, cheers!
Old Aug 25, 2021 | 09:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Don't bother changing fuel injectors... they are the SAME SIZE.
Your P72 with immobilizer delete is suspect... how about using the '96-99 GSR ECU with an OBD-2B -> OBD-2A adapter harness ?
Old Aug 28, 2021 | 05:24 PM
02rc51's Avatar
Swapped injectors. Car runs 40% better. Gsr oem injectors, oem em1 ecu installed,
was pulling vtec great. Drove it over 30-40 miles. CEL came back on. Any suggestions to get it to clear smog?
I’m open to hearing some suggestions
. Thanks.
TheHeartbreakKid
Sep 18, 2010 01:34 PM
atcBrodie
Apr 20, 2008 04:02 PM
jennsGSR
Feb 13, 2007 06:45 PM
