Chipped P72 In Limp Mode
Old Aug 9, 2021 | 07:35 PM
KrookedSavage71's Avatar
Default Chipped P72 In Limp Mode
Hey Guys, Really New To The Chipping ECU But Do Have Some Knowledge. But I Have A Chipped P72 That Get Put Into Limp Mode When J1 Jumper Is Connected. I Recently Bought A New Chip Thinking That I Had A Bad Chip But Still Have The Same Problem. So Im Stuck Ive Checked All Sodering Points To See If Any Were Touching And Nothing But There Is One Part Of The EcU That Is In Question. Plz Help!!
Old Aug 9, 2021 | 09:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Chipped P72 In Limp Mode
Chipping ? Do you know what year this is ??? Chipping is for Fox body Mustangs... there are much better solutions for your Honda/Acura platform. I suggest you get your ECU to someone who can replace your basic socketing for Hondata s300 socketing and invest in some 2021 technology... like a s300. At least then you will be able to "see" what information is running your engine, instead of taking the word of some EBay seller who made a chip "just for you".
Old Aug 10, 2021 | 03:59 AM
Ive Bought All My ECU Parts From HA Motorsports Only Reason I Went With Chipped Ecu Socket Was Beacause I Already Had The Chipped ECU It Was A Gift From One Of Buddies. So It Just Be Better To Run S300?? Rather Than Chasing This Ecu?? I Believe The Year Of The Ecu Is Like 95 its A P72 A01. But I Would Love To Try To Diagnose Whats Wrong With This ECU Just Get A Better Understanding.
Old Aug 24, 2021 | 05:46 AM
GhostAccord's Avatar
What tuning software and EEPROM burning hardware are you using?
Is the chip that you are inserting have the necessary ROM burnt to it?
It is really hard to diagnose a chipped ECU without knowing/seeing what components have been added.
S300 still needs a chip modified OBD1 ECU to run. You can work with what you have once you find out what the issues is with it.
Old Aug 25, 2021 | 04:27 AM
Im Currently Using CROME Gold And I Have A SST 27SF512 Chip. I Use The Moates Burn2. I Looked Up Evrything On The ECU Just To Make Sure Everything Was There. And Its All Installed Correctly. I Will Have Another Reply With Pictures Of The ECU.
Old Aug 25, 2021 | 04:35 AM
OK so with Crome you have to make sure that the checksum routine is removed from the .bin file. If it is not removed it will cause a CEL.
http://www.moates.net/zips/crome/Tun...ME%20v1.06.pdf
Old Aug 25, 2021 | 04:45 AM
Okay Checksum Removed And Here Are The Pictures Of The ECU Hopefully The Quality Isnt Bad When I Post Them
Old Aug 25, 2021 | 04:46 AM
Old Aug 25, 2021 | 04:47 AM
Old Aug 25, 2021 | 06:50 AM
I'll take a better look at those pictures when I get home tonight. One thing I have been doing lately with these older ECU's is replacing the capacitors. I think Moates or HRTuning used to sell a capacitor replacement kit. While you have it out looking at it, might be something to look into.
mesonerz
Oct 1, 2007 08:23 PM
Kiniku Chunks!!!
Aug 28, 2006 10:51 AM
RC's ride
Feb 7, 2006 05:13 PM
vizsual00
18
Oct 23, 2003 02:33 PM
