Z6 head, y8 intake and z6 throttle body need help with a hose
Old Aug 2, 2021 | 04:41 PM
Sleepy Drifter's Avatar
Default Z6 head, y8 intake and z6 throttle body need help with a hose
Not sure where to route this hose. I’m pretty sure it’s the fast idle control valve but I’m not sure. Thanks I’m advance
Old Aug 2, 2021 | 07:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Z6 head, y8 intake and z6 throttle body need help with a hose
That is the coolant circuit for the FITV (Fast Idle Thermo Valve). In your photo, the hose on the left goes to the IACV (Idle Air Control Valve) mounted to the back of the intake manifold, and the hose on the right goes to either a male fitting on the thermostat housing/intake manifold OR to the upper radiator hose neck on the front right corner of the cylinder head.
If you live in a Southern part of the US, connecting this isn't really necessary. It is critical for colder/Northern climates.
StuckInTexas
Feb 12, 2015 10:38 PM
foam
Nov 15, 2006 01:06 PM
zeekekciv
Aug 10, 2006 04:01 AM
spun Vtec
Jan 31, 2003 08:42 AM
