Honda CR-V & Element 2WD & 4WD Element & CR-V
Power Window Not Working (Rear Passenger)
Old Aug 1, 2021 | 09:47 AM
cot266's Avatar
Default Power Window Not Working (Rear Passenger)
Hello all.
So my rear passenger window does not work from the rear passenger switch on my 2011 CRV. It does work from the driver side switch, so I think that rules out any issues with the window motor.
I removed the right rear switch and plugged in the functional left rear switch, and it still didn't work. So that rules out the switch.
I looked at the fuse (fuse 32) and it looked fine. I replaced it just to be sure, and it still doesn't work.
What else could it be? I'm thinking it must be the wiring/harness, but I'm a noob when it comes to diagnosing electrical components.
Old Aug 1, 2021 | 02:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Power Window Not Working (Rear Passenger)
Test for power on the purple wire terminal no. 4 of the connector to the rear passenger switch. There should be power at that terminal with the ignition switch in the ON position (car does not have to be running).
Old Aug 3, 2021 | 05:39 AM
cot266's Avatar
I think that is likely the problem, that there's no power to the switch. I hope to further diagnose this week and I'll follow up. Thank you very much for the prompt reply!
Old Aug 3, 2021 | 07:42 PM
cot266's Avatar
Thanks tech8! That was indeed the problem. I checked the purple wire for power, and there was none. I looked in the door cavity, tugged on the purple wire, and out it came. It was severed at the door hinge area. Got it all fixed up. Thanks again!
einzelherz
Aug 26, 2013 06:41 AM
Myechtatel
Jul 8, 2013 08:00 AM
SiHatchTurbo
Apr 1, 2012 12:34 PM
harwood39
Oct 24, 2004 06:37 PM
