some quick n00b questions..
Old Nov 17, 2002 | 02:38 AM
crxmadman's Avatar
Default some quick n00b questions..
1. Shock fork bent when unbolting the LCAs, should i toss the shocks? or can i just bend the forks back into shape??
2. The LCA bolt is seized to the bushing...i've got the bolt turning, but i cant seperate it from the bushing!! any tips?
TIA
[Modified by 4doormadman, 11:39 AM 11/17/2002]
Old Nov 17, 2002 | 06:26 AM
cjames235's Avatar
Default Re: some quick n00b questions.. (4doormadman)
yes you can bend the fork back and it will be fine. as for the bolt seizing if it is turning you have more than likely ripped the bushing to pieces inside the lca. this happened to me so i just went to honda and bought a new lca and shock bolt. or you could buy the poly bushing kit and replace all the bushings but that costs more than a new lca and bolt
Old Nov 17, 2002 | 06:31 AM
memphiss13's Avatar
Default Re: some quick n00b questions.. (cjames235)
a polyurethane bushing kit is about $120 from summit
Old Nov 17, 2002 | 07:09 AM
JBG's Ferio's Avatar
Default Re: some quick n00b questions.. (rookie2nr)
That's the only way to go. As for the seized bolt, you may have to cut it out, not sure. But definitely get the plyurethane bushings.
Old Nov 17, 2002 | 07:35 AM
Eee Pee's Avatar
Default Re: some quick n00b questions.. (J B G)
Don't forget to mention the HOURS of
labor required to replace those bushings.
But it is a good way to go. Solo X only got a
year on them Autocrossing, I however see
no problems yet after a year and a half.
LavishTheKid
Jan 22, 2011 05:36 PM
DeDonDeRosa
Mar 15, 2009 06:21 AM
rdaggett
26
Apr 12, 2005 09:37 AM
Cyberdx16
Apr 17, 2004 03:17 PM
BoM
Aug 22, 2001 08:51 AM
