What the hell is this part? Found under hood (2004)
See attached photos. I was tearing out an aftermarket security system today (nightmare!). What is this device? Is it part of the alarm system? Is it OEM? I found this dangling near a rusted and rotted hood switch. I guess the switch was installed as part of the anti-theft system. One wire appears to be missing and the other went into the factory wire loom. Car starts and runs fine after removing the alarm system.
Thanks for looking!
....Sean
Re: What the hell is this part? Found under hood (2004)
Diag port... OK. That could explain it. Ya, the way the blue wire was still connected to the factory loom made it look OEM.
But I was not sure because some dipshit tech cut into the wire and then wrapped another wire around it headed to something. The other wire went nowhere. This was also the spot where they located the alarm siren. I pulled all this "Borg" **** from under the dash.... It's running so it's not that important but I would just like to know what the hell it is.
That is the Tachometer test port. Many people use this wire to run an aftermarket 5" Tach inside the car... or fix tach signal on a 6G Civic with an aftermarket distributor.
