D15b with P28 head
Old Jul 12, 2021 | 04:42 PM
SlowlyProgress's Avatar
Default D15b with P28 head
Hello, I have bought a 97 integra gsr that the seller swapped a d15b with. I’m in the process of getting started on thinking what I want to do with it. I need some help, since this is my first acura/honda im working with.
I checked the engine name, says it is a d15b. I’m not sure if this is the jdm or not, so I checked to see the head name, and it showed P28. When I look this head up, it says this head is from a D16a1 (pretty sure), and I’m not sure what to do now.
I would like to either get the proper ecu, which in my mind is a p28 chipped to p08 for the d15b, but I dont know if thats compatible woth my head. Im pretty confused here and not sure how to continue my build. Thanks
Head
Block
Old Jul 12, 2021 | 05:41 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: D15b with P28 head
You might start by looking at the head stamps to see what you have. They are usually around the exhaust ports.
The P28 stamp you have pictured is not on the cylinder head, it's on the plastic timing belt housing.
Old Jul 12, 2021 | 06:55 PM
Alright cool, Ill check tomorrow. I hope this isn’t a mini-me swap. Thanks, and ill update this tomorrow morning
Old Jul 13, 2021 | 05:05 AM
Looked near the header, and only found a serial Im pretty sure for the head. Ill show a pic below
Serial (I think)
No other info on the head, heres a more zoomed out photo
Tim Watford
Mar 22, 2016 06:51 PM
boosted95si
Engine Management and Tuning
Feb 6, 2011 04:47 PM
LS94tegra
Jan 12, 2010 04:46 AM
