Hot weather no start
Old Jul 5, 2021 | 12:39 PM
PMCdel sol's Avatar
Default Hot weather no start
93 del sol won't start when ambient temp is above 85 F. Replaced the fuel pump. no help.
Old Jul 5, 2021 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Hot weather no start
Check your ECT and IAT sensors... either of these reading way wrong will cause huge start up issues.
Old Jul 7, 2021 | 08:18 AM
susuking's Avatar
More description needed, Does it prime? Do you hear the master relay click? There are way too many possible just base on what you said, but I am sure it is a solder crack issue since it only happen when ambient is above 85F
Old Jul 7, 2021 | 11:10 AM
PMCdel sol's Avatar
The engine turns over so I can't hear whether any relays are clicking. Based on your response/questions and the response I got from JRCivic1 and some videos I've found on YouTube I believe it is probably the PGM-FI relay. I am old and do not do any work on cars anymore beyond washing them and I don't do too much of that. Over the next few days I will try and get this part replaced and then monitor progress. Thanks for the help.
Old Jul 12, 2021 | 03:53 AM
quenepon69's Avatar
It’s the Main Relay.. it looses its solders when it’s hot.. take it out, open it and check the solders.. try to get a new one and it will work..
Old Sep 3, 2021 | 10:31 AM
PMCdel sol's Avatar
I replaced the main relay and after close examination with a magnifying glass I couldn't see any problems with the solder joints on the old relay. I had to wait for some hot weather to test it. Over the last couple of weeks we've had some seriously hot and humid weather - insufferable. Del Sol started every time. Thanks for the help.
guitarma
Sep 26, 2011 12:46 AM
AaronGeisinger
Dec 11, 2010 05:15 AM
94EG2B18
63
Aug 31, 2009 08:14 PM
4ghatch
Mar 10, 2007 10:08 PM
