Safe basemap to use until I get my car dynoed?
Old Jul 4, 2021 | 06:10 PM
doriand01's Avatar
Default Safe basemap to use until I get my car dynoed?
Hi everyone! My Turbo D16 Del Sol blew up (likely due to running open loop on a shitty basemap for too long) and I'm planning to go B20 turbo for the next motor. Once I get it up and running, What would be a safe and reliable basemap to use to drive until I can get it tuned? That car is my daily (and only car) and my job is half an hour away so commuting has been difficult without my car. Is there a basemap I could use that would be safe enough to drive for a week or two until I can get it tuned? Thanks for the info, and take care!
Old Jul 7, 2021 | 02:44 PM
Sic_DA_Nine's Avatar
Default Re: Safe basemap to use until I get my car dynoed?
i have not had to use basemap/ecu services in about 10 years so i dont know if these companies still provide service or if their rep is still good.
phearable
j-k tuning
xenocron
but if i was in your shoes, i would schedule an appointment with a tuner on day off and just have the vehicle towed there.
back then, 90% of people that used a basemap, for some odd reason, decided that it was "good enough" and never get their car tune. they end up ripping on it and blowing up their engine then blame it on the company that provided the basemap.
dont be that guy.
Old Jul 7, 2021 | 02:46 PM
doriand01's Avatar
So I called up Inline Pro (planning on having my car tuned by them) and asked if it was safe to run it on a stock basemap before getting it tuned. They said it should be good so long as I use stock basemap and injectors, and make sure to always keep the car out of boost. So I might end up doing that!
Old Jul 7, 2021 | 02:58 PM
if you have a upgraded map sensor, swap oe one back on for your trip. good luck
Old Jul 8, 2021 | 11:50 AM
TheShodan's Avatar
Moderator
And disconnect the I/C pipe at the throttlthrody. (No, you will not overspeed the turbo as long as the oil lines to the turbo are hooked up.)
Old Jul 9, 2021 | 10:11 AM
spAdam's Avatar
Loved
Community Favorite
Or remove the WG spring so it can't build boost. Then you can go tune your part throttle/off boost while you kill time before you get to the dyno
Old Jul 9, 2021 | 06:26 PM
EWY's Avatar
EWY
What tuning platform are you using and does the car have a wideband?
Old Jul 10, 2021 | 06:27 PM
TheShodan's Avatar
Moderator
removing the i.c pipe does the same thing and requires even less work.
h22_crx
Mar 12, 2006 05:56 AM
dohc-nyne
Jun 3, 2003 04:52 PM
johnzm
Aug 23, 2002 09:03 PM
KooK
Jun 28, 2002 06:41 PM
Draceteam
Mar 25, 2002 06:11 PM
