What is this hole on dpfi throttle body?
Old Jun 27, 2021 | 12:28 PM
ax77's Avatar
10 Year Member
Default What is this hole on dpfi throttle body?
I'm smoke testing for vacuum leaks and am getting smoke out of this hole under the tps. Does anyone know what the hole is for and is it normal for air to escape? I've noticed some throttle bodies on ebay do not have it and some do. Not sure if it is an auto/manual thing.
Old Dec 16, 2022 | 12:53 PM
HontechDD's Avatar
Default Re: What is this hole on dpfi throttle body?
I'm currently dealing with this same issue I believe. High idle caused by vacuum leak from that hole. Did you manage to figure out a solution? I will post an update if I figure it out.
Old Dec 19, 2022 | 06:18 AM
ax77's Avatar
10 Year Member
I came to the conclusion that it was a vacuum leak by design. Try covering it if you're doing a smoke test and make sure you don't have smoke anywhere else. Disconnect the idle solenoid and see if the idle drops to normal. If it does you'll have to remove the solenoid and clean it. How high is your idle?
Old Dec 19, 2022 | 09:21 AM
HontechDD's Avatar
Turns out that wasn't the issue, I thought I had plugged that hole with my finger and the engine died because of it but instead I just have nudged the iacv connector loose. Which immediately killed the car. IACV is brand new. Engine was warm but I suspect there may have been an air pocket. I still think there's a vacuum leak, possibly the throttle body gasket. And yes I think you're right about that hole having a vacuum leak by design. Waiting on a new throttle body gasket, I'll go from there.
Lith ium
Mar 7, 2017 09:58 AM
spermdoggy
Jun 4, 2012 06:58 AM
FATninja19
Jun 26, 2006 10:51 PM
Shreik
Aug 3, 2003 01:08 AM
