Assistance Needed: Swap B20z2(Auto) to JDM B20B. What is required?
What exactly do I need to do to get this swap done correct?
There is not a lot of information available so any and all guidance is appreciated. Chime in.
Last edited by TheShodan; Jun 21, 2021 at 10:48 AM. Reason: Please stop yelling. I don't care if you only like ALL CAPS. We don't.
Swap the entire intake manifold and the oil pump from the B20Z2 to the JDM B20B. There are many versions of the JDM B20B, so there may be small differences between your engine and the B20B that you intend to install... such as the water pipe or thermostat housing. You will also need to utilize the distributor from your B20Z2.
