Stalls on inclines, unable to restart
Hi all. When I am on an incline and stopped at idle, my car's idle will drop, and sometimes it'll stall on its own. When this happens, or when I stall it trying to hill start, the car is unable to start again. It cranks, but doesn't start up. When I push it back onto flat ground, it'll start up just fine again.
I'm pretty sure it's an issue with the fuel system (low fuel pressure?), but I am unable to narrow down the problem any more than that. Has anyone also had this issue, or does anyone have any suggestions? I'm definitely going to replace the fuel pump.
The car is a 1994 del Sol with a B18C1 swap and mid engine conversion. The stock fuel tank is in the front under the hood.
Thank you, I will take a look at the fuel pump. I will conduct a fuel pressure test first, on flat ground and at an incline just to make sure it IS a fuel pressure related issue. Too bad the fuel rail doesn't have a Schrader valve.. I'll have to cut the hose to fit an adapter
teg racer 877
Apr 7, 2010 09:53 PM
JKingCivicSi
14
Apr 18, 2008 07:24 AM
zsudz922
Jan 9, 2008 07:49 AM
