Honda CR-V & Element 2WD & 4WD Element & CR-V
02 CRV misfire / struggle's to light off
Old Jun 15, 2021 | 12:14 PM
sf340b's Avatar
5 Year Member
Default 02 CRV misfire / struggle's to light off
02 Honda CRV at start up misfires / struggles to light off or start. Most of the time smooths out after maybe 10-15 seconds. No codes other than the misfires from time to time.
Compression (1-4) 167, 170, 175, 174 with cyl 1&2 dry and cyl 3&4 fairly wet/oily inside but no observed puddles. All plugs were nice and dry and are fairly new. Approx 150K plus miles.
The oil may be the reason I get better compressions in 3&4 but I figured I would check with the masters as to where the oil was coming from (rings, valves, or some other option) and if it was the cause of the struggle to light off.
Thanks.
Old Jun 15, 2021 | 04:20 PM
starchland's Avatar
Default Re: 02 CRV misfire / struggle's to light off
How much oil and coolant are you burning?
Old Jun 15, 2021 | 05:03 PM
sf340b's Avatar
5 Year Member
Has not been burning oil generally. Several fill ups and no oil loss. Did go through a full quart on a long drive the other day. Have not checked the coolant lately as it also stays full.
BrandyLovesHops
May 27, 2015 03:25 PM
ChangT
Oct 3, 2012 09:32 PM
kloscivicsi
Honda S2000
Mar 30, 2007 05:05 PM
MooreBoost
Honda S2000
Dec 4, 2003 05:25 PM
JoshRambo
Jul 14, 2001 09:03 PM
