2002 Honda Civic 2rd coupe
Some years the right side power window began acting up intermittently with either button. Then the left side window began the same- sometimes working, sometimes not. Before I had time to troubleshoot the window issue, the left power lock stopped working. I knew I could address that problem easily so I went to Pick N Pull and grabbed a left side lock actuator. After installing it everything began working again and has continued to work for several years until a few weeks ago the right power window has once again begun to intermittently stop working with either switch. It'll be fussy for a couple days and them be fine for a week.
My question is, are all the door electronics interconnected via the two connectors attached to the left side power lock actuator?
