2020 Insight Starting Problems
I have an Insight (2020) that has no power at all unless I start the car by pushing the key fob into the start button on the dash. I can't use power windows, open the trunk, open the gas flap, can't do anything. The start led will just flash white for 30 sec or so until I physically depress it using the fob. I changed the battery in the fob already with no change. Has this happened to anyone else? Suggestions?
You're welcome. To give you a little more info. The back-up fuse will need to be installed during PDI (Pre Delivery Inspection). Without that fuse, it will have the same symptoms you described.
pendejon
Mar 10, 2006 03:12 PM
