2020 Insight Starting Problems
I have an Insight (2020) that has no power at all unless I start the car by pushing the key fob into the start button on the dash. I can't use power windows, open the trunk, open the gas flap, can't do anything. The start led will just flash white for 30 sec or so until I physically depress it using the fob. I changed the battery in the fob already with no change. Has this happened to anyone else? Suggestions?
Re: 2020 Insight Starting Problems
Check No. 19 BACKUP MAIN (10 A) fuse located in the under-hood fuse/relay box.
Originally Posted by tech8
(Post 52430618)
The symptoms you described can be caused by the blown back-up fuse.
Thank you so much for your help!
You're welcome. To give you a little more info. The back-up fuse will need to be installed during PDI (Pre Delivery Inspection). Without that fuse, it will have the same symptoms you described.
