Missing Wire?
Old Jun 9, 2021 | 11:26 AM
Mike S.'s Avatar
Default Missing Wire?
Does anyone know what connects to the black/yellow wiring harness on the top of driver's side strut? My buddy down in TX had his del Sol jacked, and got it back but won't start.
It's a del sol VTEC.
Old Jun 9, 2021 | 12:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Missing Wire?
That is Junction Connector C128. There should be a cap on it. The cap functions to connect the terminals together (i.e., terminals grouped together are connected by the same bus bar). See this link for images of other junction connectors: https://honda-tech.com/forums/honda-...ector-3231588/
It is used to split/distribute power (via the yel/blk wires).
C128 distribute power to the following:
  • Injectors
  • EVAP purge control solenoid valve
  • IAC valve
Old Jun 9, 2021 | 01:54 PM
Mike S.'s Avatar
Thanks for the reply Tech8. So the cap shouldnt have wires, it should look like the below. If so, any idea where I can buy one? I Googled search and wasnt able to find. There are 8 pins and looks like I would need a "female" type of cap.
Old Jun 9, 2021 | 02:41 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Post # 5 in this other thread also shows an end cap (pulled out). https://honda-tech.com/forums/honda-.../#post49208237
I am not sure where you may be able to get one other than a salvage yard.
lamisilftw
Mar 31, 2012 03:37 AM
Chim64
Oct 13, 2009 09:39 PM
jena_blondie
Dec 10, 2008 10:23 AM
rewerbcrx
Feb 19, 2008 08:42 AM
