Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
4 Symptoms That Your Connecting Rod Needs To Be Replaced
Old Jun 8, 2021 | 10:00 PM
MaXpeedingRods's Avatar
Default 4 Symptoms That Your Connecting Rod Needs To Be Replaced
A connecting rod needs to be strong and durable for the engine to survive. If it’s too weak to handle the load of the combustion, then all the pressure will wear it down and bend it out of shape.
As for the driver, they will be able to notice when this occurs because there will be some very noticeable symptoms present. Below are the top 4 symptoms of connecting rod failure.
Low Engine Oil
If you have a bad or failing connecting rod, then it may cause your engine to consume too much oil. Because of this, you may find that your engine always has a low level of oil.
Either that or your existing oil will need to be changed more often than usual.
Engine Knocking Sounds
When your engine is turned on and running, you may hear a knocking sound coming from it. This will be a repeated knocking sound that gets faster as your engine speed increases.
The sounds may go away after a short while, once your oil has a chance to circulate through the engine components and lubricate them.
Reduced Oil Pressure
A bad connecting rod could have devastating effects on your engine’s oil pressure. There may be an oil pressure gauge on your engine which will tell you when it has low oil pressure.
You could have a warning light on your dashboard that will tell you as well. If you have low oil pressure, then it means the oil cannot circulate properly through the engine.
This might lead to an overheated engine if the problem is not resolved quickly.
Bent or Damaged Rod
If you suspect that you have a bent or damaged connecting rod, based on the other symptoms which may be present,
then you need to visually inspect the rod yourself to see what its condition is.
This would require your engine to be disassembled, which is a job that only a mechanic should do.
If the above situation occurs, then this means that you need to replace the new connecting rod.
MaXpeedingRods high-performance H-Beam connecting rods with Forged SAE 4340 Chrome Moly Steel for the highest strength and durability, dedicated for street and race vehicles.
Get your pistons pumping with tough, top-quality connecting rods from MaXpeedingRods
for more Honda-related accessories information, enter maxpeedingrods.com
|Facebook| YouTube | Instagram |
MaXpeedingRods
Performance
Apr 26, 2021 01:35 AM
John Mayfield
Engine Machining & Assembly
11
Oct 14, 2019 03:33 AM
RACEPAK
Sep 18, 2010 06:52 AM
soeurm
Jan 11, 2007 10:19 AM
s2kkid
Mar 5, 2005 04:36 PM
