1995 Del Sol AC Static Low Pressure is High
Hi guyz,
I have a 1995 Del Sol and I used a Harbor Freight Manifold Gauge to test pressures Static and Car turned on:
STATIC:
Low Side: Maxed Out
High Side: 140 psi
Vehicle Turned on with AC on Maximum
Low Side: Zero
High Side: 150 psi
After shutting off car:
When I took off the High Pressure gauge line it had refrigerant in the line
When I toook off the Low Pressure gauge line it was empty.
I have had AC Evac and Recharged by a shop but it still blows hot.
Compressor Clutch activates and turns continuously
Condensor gril is clean
Air blend Valve opens and closes normally and is unobstructed
Any ideas why it would have these readings and why it would blow hot?
STATIC:
Low Side: Maxed Out
High Side: 140 psi
Low Side: Zero
High Side: 150 psi
redman8741
Aug 2, 2018 04:22 AM
koondawg
Acura TL, RL & ZDX
Jul 12, 2005 08:37 PM
B16Drag
Oct 22, 2004 10:18 PM
