Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic 2013 ex l ac relay
Old Jun 4, 2021 | 04:17 PM
Carol Martin's Avatar
Default Civic 2013 ex l ac relay
Battery drain on civic it has been suggested ac relay gets stuck on and could be the issue problem is I don’t know which relay it is. Every diagram is different nothing is marked ac
Old Jun 4, 2021 | 04:29 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Civic 2013 ex l ac relay
There is a Honda service bulletin (TSB A12-041) regarding a new software update the vehicle did not start due to a low battery. The condition of the battery also needs to be checked and possibly replaced.
POSSIBLE CAUSE
The vehicle’s battery sensor monitors battery condition and the PCM determines charging mode. Based on the sulfation of the battery and customer driving habits, the PCM may not select the correct charge mode.
Edit: I just double checked, your year Civic is not part of the service bulletin, only certain 2012 Civics and 2012 - 2014 CR-Vs.
Old Jun 4, 2021 | 04:50 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Although this may not be the cause of your battery drain issue; to answer your question, this is the AC compressor clutch relay.
Old May 2, 2024 | 10:57 AM
tmrosebr's Avatar
I know this is way late, but what's your source on that? I need to replace my starter relay but I can't for the life of me find a diagram that tells me which is which.
ajpal
May 24, 2018 10:50 PM
Swishier
Jul 5, 2017 12:58 PM
akb427
Honda Civic (2001 - 2005)
Jun 28, 2013 08:51 AM
