Honda CR-V & Element 2WD & 4WD Element & CR-V
2004 CRV: Air Conditioner Temperature Inconsistent
Old Jun 4, 2021 | 12:46 PM
DX97civic's Avatar
Icon4 2004 CRV: Air Conditioner Temperature Inconsistent
Howdy,
Just bought my brother in laws CRV from him and noticed the A/C blows cold, then warm, then cold, then warm and so on... It is inconsistent. I ruled out the fuses and cooling fan. Thoughts?
Thanks!
Old Jun 5, 2021 | 10:11 PM
Davey7847's Avatar
Default Re: 2004 CRV: Air Conditioner Temperature Inconsistent
Can you verify that the AC compressor is cycling regularly. When the air from the AC is warm , is the compressor still cycling of is the clutch released.
If the compressor is normal in operation, the issue may be in the air mix door.
Heres some diagnostic info.
Old Jun 6, 2021 | 12:09 PM
DX97civic's Avatar
Thank you for this suggestion. I ran the protocol, it cycled the AC on briefly and then recirculation and AC indicator/buttons remained off. I would surmise that it checked and that there are NO errors or DTCs found.
Old Jun 6, 2021 | 04:10 PM
starchland's Avatar
Low pressure in the system is my guess
Old Jun 6, 2021 | 05:46 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Does it cool while driving, start to warm up once you come to a stop, and then cool when you start accelerating again?
Old Jun 7, 2021 | 05:33 PM
DX97civic's Avatar
Yes, but it is not the condenser fan which this is normally a symptom of?
Old Jun 7, 2021 | 05:48 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
It is also a symptom of low freon/pressure in the system.
It's more like it'll still cool while sitting and when you start accelerating and the rpm spin up the compressor it will get humid and stop cooling for a second as the freon is moving around the system again.
@muellersfan can explain it better than I can.
Old Jun 10, 2021 | 06:09 PM
DX97civic's Avatar
Gathered all the necessary items to re-charge or fix low pressure situation. Minute I attached the hose to the "L" port it SHOT to the max of the red for pressure. Seems previous owner over pressured it? Is there any easy way to fix this and would being over pressured cause the same symptoms as under pressured?
Old Jun 18, 2021 | 03:35 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Over charged system will cause similar symptoms so I've heard around the shop. I'm guessing you don't have a proper set of gauges to see what's going on with the high-side do ya? If you did, maybe you'd have a better idea of what's going on besides "overcharged"... could be something causing a restriction which is increasing pressure even if you've got the correct amount of r134a in the system.
Old Jun 22, 2021 | 05:19 AM
powercycle's Avatar
I had this same issue just recently. Compressor was turning off and on especially when I'm on a stop. At first I thought there was something wrong with my magnetic clutch but after checking the pressure on the low side it was overcharged.
Lithel
Oct 3, 2023 12:51 AM
lsturboguy
Sep 4, 2006 01:37 PM
Tricid
Jun 28, 2006 07:36 PM
barry11j
Mar 4, 2005 11:31 AM
