[HELP] - No error code but CEL and No vtec
Old May 30, 2021 | 03:59 AM
break's Avatar
Icon4 [HELP] - No error code but CEL and No vtec
Hello all. So i just cannot find the solution for this issue. I have a B16A2, and after the normal service: oil, filters, new water pump, new coolant and new metalic coolant hose (the one from the back of the engine..) the engine started to throw a CEL error, like from nothing and after a week from the service... for example today i started the car, gently getting out of the parking lot, and CEL.. the thing is, if i stop the car and try to pull the error code (chant the two pins from the grey connector by the ECU i get nothing, i put the key to ON position, but no CEL error lights whatsoever. yesterday i was crusing and i got CEL, the car was at the temperature so i give it a pull... and no vtec...
If i stop and start the car again it run fine, vtec engages and everything run like it should... and i can stay like so for quite sometime until CEL pops again.. i just dont have any clue about what this could be... i have like a "handmade" connection to my selonoid ( since the grey connector that connects to it broke... i connected it directly, but its like that for like an year or so.... could this be it??? that with the turbulence or something it does a bad connection and throw CEL.. but then why i cannot pull any error code?? the light simply stays off if i try to pull the error code like i said before... )
The engine has no abuse, i only push it with good temperature and always check the oil level and everything, basically im cautious about the car.. its my weekend summer car..
Please help me!!
Old May 31, 2021 | 04:30 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: [HELP] - No error code but CEL and No vtec
When you try and pull the code is that before or after shutting car off when the CEL comes on?
Old May 31, 2021 | 12:47 PM
break's Avatar
Its right after it cames on, drive a bit until i can stop the car, chant the connector, put key at ON position and no light, it should blink.. but stays off.. i really dont know why.. even the car doesnt behave badly or struggle to pull,it just the vtec that doesnt engage when its on, but like i said, if i stop the car and start it again, its all fine, vtec engages all working good... dont understand..
Old May 31, 2021 | 08:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You need to check the code BEFORE you shut the car off... you may have an issue with code memory that could be simple or could be complex... so once the CEL comes on, pull over, leave the car idling and shove your paper clip into the service connector. Then let us know what the code is.
Old May 31, 2021 | 10:52 PM
break's Avatar
I never thought it could be done like that, i always thought that the car needed to be off... so if i can do that i will test it as soon i have the error again.. could this be the ecu that is going dead??
Thank you for your help!!
Old Jun 3, 2021 | 02:16 PM
wunfstgsr's Avatar
Loved
Community Favorite
Please help me!!
You need to properly connect the plug! Just buy this and thank me later!,
VTEC Oil Pressure Switch Solenoid Plug Pigtail for Honda Accord Civic Prelude | eBay
Old Jun 5, 2021 | 12:14 AM
break's Avatar
Update- so far the CEL didn't popup again.. strange..
I will definetly need this two vtec connector, will check if i can find it here!!!
Thank you!!
Old Jun 5, 2021 | 12:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
Thank you!!
Why would you check if you can find it here? I shared the ebay link its $6 shipped cant beet that..
Old Jun 5, 2021 | 01:07 PM
break's Avatar
No friend, it cannot be shipped to Portugal.
I will find it here for sure!
Old Jun 5, 2021 | 07:58 PM
wunfstgsr's Avatar
Loved
Community Favorite
Owe got you!
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
Parada
Mar 9, 2007 05:02 PM
aych2h
Oct 19, 2006 09:01 AM
92HB_HB
May 12, 2003 12:23 PM
