Honda CR-V & Element 2WD & 4WD Element & CR-V
99 crv with loose front left wheel (video)
Old May 28, 2021 | 11:47 AM
thecorey's Avatar
Icon5 99 crv with loose front left wheel (video)
hey there, i have a 99 crv that's been making a clunking sound in the front end when going over bumps. i finally got it up off the ground to check it out.. and as you can see in the video, there's about a half inch of horizontal play. don't think it's the wheel bearing, cause it only wobbles left/right. there is no up/down play. also checked the right side and there's zero play, so the right side seems to be fine.
crv wheel wobble
the video has audio, and you can def hear metal clanking when i move the wheel back and forth.
Old May 29, 2021 | 06:47 PM
Davey7847's Avatar
Default Re: 99 crv with loose front left wheel (video)
You can see the inner tie rod is loose in your video
Another_Si_Guy
23
May 19, 2015 05:59 AM
Crosseman
Apr 14, 2015 09:07 AM
TomCat39
Jan 5, 2015 08:06 PM
superhatchbackbros
Apr 11, 2010 03:23 PM
eightyHD
Aug 17, 2005 05:18 PM
