1989 Honda Civic crank angle sensor
Old May 26, 2021 | 09:13 PM
thatcumminsguy's Avatar
Default 1989 Honda Civic crank angle sensor
Hello all I’m looking into buying a civic runs and drives great but you make it a mile down the road and the check engine light comes on and scans back to code 4 and it will keep running fine but you punch it and if it gets to 3500 rpm it almost sounds like two step and tries to die let off or grab another gear and it’s back to normal any suggestions on what it is and how to test or fix this I want the car but am not gonna buy something with problems thanks in advance
Old May 27, 2021 | 06:31 AM
jlicrx's Avatar
Default Re: 1989 Honda Civic crank angle sensor
needs a distributor
Old May 28, 2021 | 11:38 AM
Originally Posted by jlicrx
needs a distributor
how hard is that to replace
Old May 28, 2021 | 02:26 PM
jlicrx's Avatar
pretty simple - you will need to adjust the ignition timing after it is replaced
Old May 31, 2021 | 06:16 AM
Marcos Barrios's Avatar
code 4 means that the civic is in limp mode
thats why you cant rev to high
the fix could be the distributor
but it can also be a timing belt thats not installed corectly
it could be off by a tooth or two and thats why your computer is saying that the crank angle is wrong get it?
and it can also be a 02 sensor thats not connected correctly
hope that info helps
civic1999si
Nov 2, 2019 06:25 PM
calrodz
Honda Civic (2006 - 2015)
Feb 13, 2016 07:29 PM
01 Honda Civic
Honda Civic (2001 - 2005)
Jun 8, 2012 07:09 PM
pityocamptes
12
Dec 14, 2011 09:48 AM
DIRTYBYRD79
Aug 28, 2009 01:01 PM
