99/00 SI rear sway bar
Old May 25, 2021 | 01:41 PM
HellSoldyr's Avatar
Default 99/00 SI rear sway bar
I've been trying to find the rear sway bar for my 98 EX and I don't seem to be having any luck anywhere, anyone seen or has or wants to sell one? I can get brackets, bushings and links but wouldn't mind if it has them already.
Old May 25, 2021 | 08:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 99/00 SI rear sway bar
It is discontinued from the Dealership... you will have to find one on the used market. Have you considered something slightly larger from the aftermarket ? This path will likely be easier to navigate.
Old May 26, 2021 | 03:45 AM
HellSoldyr's Avatar
I've been looking at some, most are 24 and 26mm I didn't want something so aggressive, the only one I found that is smaller is a 18mm from nolathane, which if I can't find the si one I'm probably going to go with.
Old May 26, 2021 | 05:57 AM
spAdam's Avatar
Loved
Community Favorite
OEM Type-R bars can still be had from the importers and are really not that aggressive. The only downside I can see is that you will definitely have to run subframe reinforcement to use them. The other option for a small bar would be to hit the local pick 'n pull and nab one of of any non-R Integra. They are 14mm. You'll need to get very slightly creative with the endlinks.
Old May 26, 2021 | 11:18 AM
HellSoldyr's Avatar
I found 2 Integra ones on eBay, they look okish I'm gonna take a ride to some pick-a-part yards on saturday see if I get lucky with anything.
Old May 27, 2021 | 01:40 AM
tony_2018's Avatar
Fish Twig
I think the EM1 was a 14mm
Old May 29, 2021 | 09:43 AM
HellSoldyr's Avatar
Got a complete bar off a Integra at the junkyard, they were also doing a 50% off everything for memorial day, came out to $8 for bar with brackets, links, and bolts.
Old May 29, 2021 | 10:34 AM
spAdam's Avatar
Loved
Community Favorite
Boom. Well done.
Old May 29, 2021 | 11:36 AM
tony_2018's Avatar
Fish Twig
Still need the correct endlinks, brackets and d brackets for an em1.
Old May 30, 2021 | 07:36 PM
HellSoldyr's Avatar
The brackets and endlinks are no problem, the D-brackets from the integra aren't useable at all?
Old Jun 1, 2021 | 07:45 PM
tony_2018's Avatar
Fish Twig
unsure, I went and bought everything for an em1 to ensure no hiccups. endlinks and bushings came from hardrace, brackets were oem new.
Old Jun 3, 2021 | 01:30 PM
HellSoldyr's Avatar
I just took a look at a 99 civic and a 00 integra from some friends and the brackets are different, the ek brackets sit flat on the frame, the integra brackets are offset with one bolt sitting deeper than the other. so i got some integra rear sway bar brackets and tie rod brackets if anyone wants em.
Old Jun 17, 2021 | 01:14 PM
subgeniusdude's Avatar
Only the EM1 Si's came with a rear bar to my knowledge. Integra rear bar is 13mm hatchback and 14mm sedan. You can use the Integra brackets but one hole won't sit flush,you'll need a few washers under it to make them sit correct.EM1 endlinks will bolt right up to the lower arms as there is already a hole there but not the Integra bar ends,they are totally different and I don't think you can use the Integra endlinks with the EK . I'm running a 13mm Integra bar with EM1 endlinks and Integra brackets but I had to modify the bar ends to connect to the end links. I used some aluminum spacers and drilled the holes and fit the end link through. It works but I'd seriously get the ASR brace and bar or the Progress if you can swing it. I have a Blox 21mm bar but it'll probably rip the subframe so I haven't installed.Hope this helps I have other photos if needed.
Integra 13mm sway bar end
Integra bracket
Correct EM1 brackets not installed
Sway bar
Old Jun 18, 2021 | 06:20 AM
HellSoldyr's Avatar
I bought the ASR bar adapter kit, didn't feel like fabing something up, I'm using integra coupe sway bar, oem em1 brackets, em1 end links and some grade8 bolts, washers and nuts I got from my job, the D-brackets from the integra bar bolt right up to the em1 brackets so that's not a problem, hopefully I'll get it installed this weekend if it doesn't rain.
Old Jun 18, 2021 | 09:16 AM
tony_2018's Avatar
Fish Twig
Those washers are/were a bad idea.
Old Jun 18, 2021 | 02:24 PM
HellSoldyr's Avatar
Yeah i saw a guy on youtube weld some adapters on but i rather get the right brackets.
Old Jun 19, 2021 | 11:23 AM
tony_2018's Avatar
Fish Twig
That's even worst
Old Jun 20, 2021 | 12:21 PM
HellSoldyr's Avatar
I got it installed on this weekend, em1 brackets, em1 end links, ASR adapter kit, bolted up very easily only annoying thing is the top D-bracket bolt on the passenger side because of the stock muffler little annoying but you can get it in with no problem. BIG handling upgrade, car is much more solid in the wind, more stable in the turn in and higher speed through the corners, all in for under $50 if you have a pick-a-part near you. Best upgrade so far I've done to this coupe, coils, wheels, and SI wing coming soon.
Old Jun 23, 2021 | 06:24 AM
aw614's Avatar
10 Year Member
Loved
I ran the washer setup on my EK beater with a non Type R bar. didn't have issues with it, but as I thought, it was basically useless and just bought a cheap brace and mounted my ITR sway bar that was recently taken out of my integra when I went up to a 25mm
Old Nov 30, 2021 | 11:30 AM
I finally got rid of the 13mm Integra sway bar and ghetto fabbed brackets with washers. Honestly never noticed a huge difference and getting the EM1 end links into those thick bar ends using whatever method works for you leaves only 2-3 threads exposed to get the nut on. Thought I'd try the Emusa subframe brace,it was only like $40 shipped so why not. Actually pretty impressed with it,it's an ASR copy and quality looks very good. The long bolts that go through the control arms are garbage and not even the correct thread pitch but I had some stock D16 head bolts left over from my build which worked perfect. This allowed me to mount my Blox 21mm sway bar since I already had the EM1 endlinks. Pretty easy install and not only did ride quality increase, steering effort and cornering are much better. I think I paid around $130 for the bar,$40 for the brace,and the endlinks from Rockauto were maybe $15 for both. Great upgrade for under $200.
Emusa subframe brace with Blox 21mm sway bar
angel_i
Feb 4, 2009 11:30 AM
stuie08
Nov 25, 2006 02:30 PM
civexspeedy
Aug 25, 2006 02:43 PM
Nothing.Special
Suspension & Brakes
May 17, 2005 10:01 AM
KtotheEK
Dec 13, 2004 11:14 AM
