Did I cause wear to my OEM Clutch? 98' D16 Civic
Old May 22, 2021 | 07:12 AM
XpoZzA's Avatar
Icon5 Did I cause wear to my OEM Clutch? 98' D16 Civic
Hey guys, I changed the clutch on my car like around 350miles ago (approx. 550 km) , and I have a few questions:
Sometimes when doing a pull I can hear a sound that sounds like tires screeching when changing gears and letting the clutch out too fast w/o letting the revs drop, but I'm wondering:
  • Are those really the tires doing this noise?
  • Or is it something else in the clutch assembly?
Moreover, today I did a 1-2 pull but waited for the clutch to fully engage slowly (and normally) at first before actually going at it, I upshifted from 1st to second and did let the revs drop but just not enough, and when I released the clutch I did hear screeching noise.
Afterwards the clutch felt just a bit different and I think I overheat it a bit:
  • Is that actually possible to overheat a clutch from a quick gear change?
Anyways, after a few seconds the clutch felt normal again, but now I'm wondering:
  • Did I caused any major wear to my clutch? thanks .
NOTE: I don't ever dump the clutch from when standing still, and when accelerating and engaging the clutch I, most of the time do it while staying under 2.5K RPM, and only sometimes doing it while around 3K...
  • What's the ideal RPM to stay under when going from a stop?
  • Is it OK to start, sometimes at 3KRPM or will it cause the clutch to overheat?
Old May 22, 2021 | 06:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Did I cause wear to my OEM Clutch? 98' D16 Civic
Did you break in the clutch properly before you did any hard pulls?
Sounds like a spring or two could be broken in the disc only way to find out is to pull it out or wait till the clutch no longer works and you start grinding gears cause the clutch wont engage.
Old May 22, 2021 | 09:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Of course not... he has admitted full power pulls already and there are only about 350 miles on the clutch.
OP, what brand of clutch did you buy ? Where did you purchase it from ?
Old May 23, 2021 | 07:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
That clutch could have hot spots or damaged disc pads, OP your clutch should have came with a break in method or instructions on how many miles before the clutch is considered broken in.
jdmstyleEJ6
12
May 9, 2010 04:13 PM
Moemers
Honda S2000
12
Nov 27, 2006 06:58 AM
Jmumblez2001
Aug 8, 2006 12:05 PM
mooseknuckle
May 26, 2003 02:54 PM
