So I am having this issue with my 1996 Honda Civic 1.4i...
There is this sound behind engine like knocking. It can usually be heard when engine is warmed up and idles. When I rev it up that sound completely dissapears. Does anyone know if this is some bad thing or I should just let it be.?
Last edited by TomCat39; May 8, 2021 at 07:58 AM. Reason: Fixing color so it can be read and seen by all.
Sounds like it needs a valve lash adjustment. Loose noisy valve train.
If sound persists after a proper valve lash adjustment (done with a cold engine). Then investigate further with mechanics stethoscope.
I would redo your adjustment. It's possible (especially if you didn't torque to spec the locknuts) that some of the valves loosened up.
Do you have the factory service manual for all the specs for the valve lash adjustment?
mustafaazada
May 6, 2021 11:40 AM
atasevski
Jul 11, 2018 11:05 PM
