96 accord misfires at idle
Cylinder 4misfire
So it will missfire at idle I’m not shure if it misfires when I drive .. but I don’t think it dose. just a single cylinder .
here’s what I’ve done
Checked spark compression and swapped fuel injectors and all of those are good
what sound I do next????
Cylinder 4misfire
You are right, that sounds like a good spark. When watching it, did it ever give a low spark or always a big spark?
Are you able to watch and monitor via OBD-II to see and record all the sensors at misfire to see if anything looks out of place (like O2 or timing or something?).
And the spark plug was burned in cylinder 4 I’m going to replace them rn along with wires and cap
it may have been 3 weeks since I replaced wires and plugs
havent drove it allot mabe 60 miles
Turn off the ac and it misfires .... when I turn it on the missfire is gone
https://honda-tech.com/forums/honda-...-idle-3356844/
Solved: I think I figured this out as well . There’s actually a rpm drop. Not allot but there is one. So I don’t think its missfireing at all drive it 200 miles no code
i think the code came from the corrosion on the cap still not shure
ALSO TURNING ON THE AC PUTS A LOAD ON THE ENGINE AND WILL MAKE A DEAD CYLINDER SEEM OK ... when you pull the wires out
virgilr
May 18, 2007 10:33 AM
aln2590
Mar 12, 2007 02:03 PM
