Honda CR-V & Element 2WD & 4WD Element & CR-V
02 crv running too cold?
Old May 2, 2021 | 05:36 PM
Aabdallah97's Avatar
Default 02 crv running too cold?
My 02 CR-V doesn't get to temperature, also has HORRIBLE gas mileage. Like 10 mpg. I hear it may be the thermostat, as they fail open.
Old May 2, 2021 | 08:31 PM
thook44's Avatar
Default Re: 02 crv running too cold?
how is it running, otherwise? any check engine light?
do you have any idea how old the thermostat is?
when's the last time the coolant was changed? what was used?
Old May 3, 2021 | 06:07 AM
I have no idea what the coolant state is, it's not running all go well. The CEL comes on and off.
Old May 3, 2021 | 08:59 AM
thook44's Avatar
do you mean it's not running well or not running at all?
have you had it scanned for any codes?
do you know much if anything about working on vehicles?
Old May 4, 2021 | 08:39 PM
I meant not running too well. Haven't scanned for codes, know enough about cars for this.
Old May 5, 2021 | 12:07 AM
thook44's Avatar
a bad thermostat is certainly plausible and easy enough to replace. do that, fresh coolant, then clear the codes and see if they come back. if they do, have it scanned. you may have more than one thing going on...ie. a bad coolant temp sensor (not the gauge sensor). not saying there is, so don't be alarmed. just saying it's possible given how it's running and the poor mileage. hard to diagnose over the internet, eh
Old May 7, 2021 | 01:06 PM
uDraft's Avatar
10 mpg sounds like real trouble. Could have a bad thermostat, but that would not put you in the 10 mpg range. Sounds like it needs some real TLC. Maybe start with a compression check. Look at the plugs while you have them out. But there are a myriad of things might be wrong with your car. The stored codes may give a clue.
Old May 7, 2021 | 07:17 PM
thook44's Avatar
check the oil for coolant. make sure you haven't blown the head gasket
confidence
Nov 19, 2005 01:19 AM
MeanGreenEG9
Jan 18, 2003 12:08 PM
disordeR
Dec 29, 2002 11:48 AM
CC2
Nov 4, 2002 04:02 PM
SoNNyBoY9o9
Nov 3, 2002 01:50 PM
