Fuel gauge+Temp gauge not working after cluster swap
I know this has been asked before but my case is somewhat peculiar, I did the usual ex cluster swap into ek for the tachometer, its plug and play. First thing i noticed was temp sensor didn't move and stayed below the bottom which was no big deal, when I took the cluster out again to replace a bulb and put it back the car's fuel gauge shot up to the top and just stayed there. I dont think its the sender unit because both worked on the first cluster but I'm wondering how both gauges just stopped working out of the blue. Also, would I be able to temporarily swap in my fuel gauge from my old cluster and just not have a temp gauge for now?
Thanks in advance, I never expected something so simple to give me so much trouble.
Re: Fuel gauge+Temp gauge not working after cluster swap
Update: I swapped back in my original cluster and my temp started working since its on the left but my fuel still didn't work and its on the right, so no matter which cluster I put in, my right gauge doesn't work. Any idea as to why?
