F20b swap on a 2002 accord
Old Apr 30, 2021 | 11:41 AM
Jay castro's Avatar
Default F20b swap on a 2002 accord
I recently bought a f20b manual swap doing it on an automatic shell everything is going good but I’m trying to find a plug and play Ecu should I use an ecu from a manual f22a1 or can I plug in the f20b ecu that I have into my harness to make it work? Also would the new ecu allow me to use my stock keys due to the immobiliser please help also it’s an ex sedan with bred the motor is from 98-2002 sir accord
Old Apr 30, 2021 | 01:58 PM
Aradin's Avatar
Premium Member
Default re: F20b swap on a 2002 accord
Your best bet will be to use a jumper harness and a chipped ECU.
A professional tune is required.
Old Apr 30, 2021 | 02:32 PM
Jay castro's Avatar
which ecu would you recommended p28? And a jumper?
Old Apr 30, 2021 | 03:31 PM
Aradin's Avatar
Premium Member
You can find the required jumper harness on most of the ECU/tuning related websites like Phearable, Xenocron, HAmotorsports, etc. Lesser quality ones are also available on eBay.
Any chipped ECU will work as long as it has VTEC provisions. P28s are getting rare so if you order an ECU it will probably be a P28 equivalent. If you wish to retain ECU control of your IABs, you will need to get a P72 or P72 equivalent. You may consider ordering one from the above websites where you get your jumper harness because they do preventative maintenance on the ECU itself and will include a basemap. A basemap will allow you to start the vehicle and check for leaks before taking it to a professional tuner.
Old May 1, 2021 | 05:18 AM
Jay castro's Avatar
last question will my harness from the automatic plug into the plugs on the new engine obvi the transmission has less so they’ll be dangling etc but could use the old harness aslong as I go the chipped route with jumper?
Old May 1, 2021 | 11:10 AM
Aradin's Avatar
Premium Member
Typically the best way to do it is to use your old engine harness and modify it to work with the new engine. Generally only a few wires/plugs need to be extended. You can just tape off the old automatic connectors and tie them out of the way somewhere, or you can cut them off if you're sure you'll never need them again.
Old May 1, 2021 | 12:42 PM
Jay castro's Avatar
Default Doing f20b auto to manual swap in 2002 Honda Accord ex
Doing a full swap from f22a to f20b harness wise would my harness from the car plug into the new motor but obviously leaving the automatic transmission sensors from the harness unplugged
Old May 6, 2021 | 10:55 AM
Jay castro's Avatar
Default F20b swap 2002 accord
Hey guys you have been awesome help in this swap I have another couple questions so I’m doing the obd2 to obd1 jumper harness for ecu now my problem is the engine I got never came with a distributer and since I’m just converting the ecu to obd1 would I also need a obd1 distributer or can I just get the obd2 one be and ok? Last question does anybody have the wiring diagram for the auto manual conversion by the shifter so I can make it start
Old May 6, 2021 | 02:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your separate threads regarding the essential same topic has been merged (f20b swap into a 2002 Accord). Please do not create separate new threads for related questions.
Old May 6, 2021 | 03:30 PM
Aradin's Avatar
Premium Member
Default Re: Doing a auto to manual f20b swap on a 2002 accord ecu help and advice
If you are going to retain your OEM engine harness, you will want to use an OBD2 distributor for an H series that matches it. Likely from a 5th gen Prelude. The OBD2-1 conversion is being done at the jumper harness. As for the wiring diagrams...this swap has been done many times and the information is readily available from a simple google search.
Thanks. I was going to comment on the last one but refrained for this reason.
HostileJava
Sep 7, 2009 05:29 AM
tealsvteceg
May 25, 2008 04:18 PM
q8delsol
Nov 3, 2006 07:15 AM
CD8coupeSiR
Sep 1, 2006 08:55 PM
xwade01
Mar 15, 2005 11:03 AM
