Need Help!!
Old Apr 30, 2021 | 10:09 AM
94Accord!!'s Avatar
Default Need Help!!
I dont know where to begin this small story but i have a 94 Accord Ex with the stock f22b1. When i first bought the car it would bounce the idle up and down while under 25 mph every once in a blue moon. I would blip the throttle and all was fine till it would happen again about 2-3 weeks later. I overheated and warped the head so did a full engine rebuild. New head, block was cleaned and machined to turbo spec, seals and gaskets, alternator, trans(to be put in), plenum, intake, distributor, plugs, plug wires, iacv and fuel pressure regulater have all been replaced. Since the rebuild it has begun to idle up and down around 1000 rpm to 2,400 to 2,500 rpm constantly. Ive checked power to everything in the engine bay and all seems normal. If it helps it acts like the fuel pump is turning off and on because the pressure in the rail is rising and falling. I have no leaks and everything that has a gasket or seal has been torqued or triple checked for leaks, ive checked my coolant levels and made sure its going where it needs to go...
Any help is greatly appreciated and ill get back to any answer asap.
Old Apr 30, 2021 | 11:09 AM
Aradin's Avatar
Premium Member
Default Re: Need Help!!
My first thought was IACV but you said you replaced that.
Ensure the engine coolant is bled properly and there is no air trapped in the system. After that try adjusting the fast idle valve on the throttle body. Cleaning the throttle body and adjusting the set screw may also help.
Old May 1, 2021 | 08:16 AM
nicolaselias's Avatar
Loved
Community Favorite
I know it sounds ridiculous but does your speed sensor / speedometer work? Whenever my speed sensor died, the vehicle would do strange things like this.
Old May 5, 2021 | 12:18 AM
94Accord!!'s Avatar
The plenum on my intake is from an f22b1 that didnt have this problem... dont know if that changes anything but its making me think its electrical somewhere... i read it cold be that my car thinks its cold even at 190 degrees. Could that be causing it to rev up and down??
Old May 5, 2021 | 12:19 AM
94Accord!!'s Avatar
Every once in a while my speedometer just drops to zero and then jumps and acts weird for a minute. After it does that it goes back to normal. Could it just be on its way out??
Old May 5, 2021 | 06:31 AM
Loved
Community Favorite
Like I said, check your speed sensor and make sure it is fine.
https://easyautodiagnostics.com/hond...sensor-tests-1
Old May 5, 2021 | 05:38 PM
94Accord!!'s Avatar
Went to this link and realized immediately, not sure of i said this but i have a manual not an automatic... pretty sure i dont have an output speed sensor on my trans.
Old May 6, 2021 | 09:25 AM
99stockcivic's Avatar
it looks like you do have one:
https://www.ebay.com/itm/1994-Honda-...-/153512625171
Old May 6, 2021 | 05:16 PM
94Accord!!'s Avatar
Originally Posted by 99stockcivic
The text under the pic says F22A1... i have an F22B1... I just dont want to spend more money and have it not do anything. I do have a spare trans from my donor car thats exactly the same as mine.
Old May 13, 2021 | 10:22 PM
94Accord!!'s Avatar
New trans is in and ill be starting it back up either today or tomorrow but with the "new" speed sensor still on from the parts car that didnt have my problem. If anyones still interested in this let me know and ill check some other things it could be
Old May 14, 2021 | 07:02 AM
Loved
Community Favorite
Look forward to hearing the outcome.
You can also check the continuity/resistance across both speed sensors to see if both are good or if you are looking for a different issue (or if both are bad?)
Old May 23, 2021 | 09:03 AM
94Accord!!'s Avatar
Idle is now bouncing faster when i start it cold and after a minute it slows wayy down but continues. Vaccuum leak maybe?? The only thing that hasnt been replaced or looked over is my intake tube under the plenum. Could i have warped it when i overheated my block a while ago?? I did have this problem from the get go but it was every blue moon and would go away if i blip the throttle.
BADxKARMAx
Engine Management and Tuning
Apr 17, 2012 01:24 PM
5speeder
60
Mar 17, 2012 03:29 PM
Robbiem16
Oct 3, 2011 04:20 PM
bvillarreal
Aug 16, 2011 10:28 PM
miguel6632
Jul 2, 2005 08:58 AM
