Del Sol turns off when coming to stop
I have a 1995 Del Sol manual and it works fine when you initially turn it on. When you start to drive it and you are pulling up to a stop sign or stop light and you put it in neutral it just dies. Sometimes if feels like it’s going to die but the rpms bounce back and it stays on. I changed the iacv and I already bleed the cooling system. I know there are a lot more things I can do but I would like to see what would be next so I won’t go spending on unnecessary parts. Thank you in advance for your suggestions
https://www.qwant.com/?q=tps+officia...nda-tech&t=web
ignition coil and/or ignition control module could be biting the dust.
they will definitely both fail eventually so have a spare for each on hand.
https://www.team-integra.net/threads...ooting.342735/
i'm running ngk coil and delphi icm from rockauto.
dorman makes a decent tps for about $30.
Thank you all for the suggestions. I just bought the car a couple of weeks ago and drove it home 200+ miles without an issue. Because of work I haven’t really worked on it but I will today. 👍🏽
