Y8 into a 88 EF Sedan Motor Mount Issues
Old Apr 29, 2021 | 07:42 AM
Tre4 OG's Avatar
Default Y8 into a 88 EF Sedan Motor Mount Issues
So I built my Y8 got it into my 88 sedan EF and got the two side mounts on and went to do the trans mount and it was like half inch off. I know it’s the right one for manual trans. I had the auto trans at first and got the right one so I know it’s right. So it’s gotta be one of the 2 side mounts. Can y’all tell which one is wrong. And the driver side post mount is from the Y8. That’s my other question do I need the post mount from the d15b1,2 or something to make it right? Idk lemme know homies thank you
Old Apr 29, 2021 | 07:43 AM
Tre4 OG's Avatar
Default Re: Y8 into a 88 EF Sedan Motor Mount Issues
This is the offset trans mount so y’all can see what I mean.
Old Apr 29, 2021 | 01:35 PM
Marcos Barrios's Avatar
the bracket that goes on the head for the driver side mount needs to be from the d15b2 motor
that may be where your half inch problem is
but im not 100 percent on that
also the passenger side trans mount that your using looks like it could be adjusted on one of the bolts?
this also has to be for a d15b2 motor
Old May 7, 2021 | 06:24 AM
Tre4 OG's Avatar
Thank you so much! I’ve always had such helpful and pleasant interactions when I’m on here. I appreciate yuh my friend.
Tre4 OG
Apr 21, 2021 03:51 AM
charlie_sohc
Apr 25, 2009 09:31 PM
EJ8CIVIC
Sep 22, 2008 06:14 PM
Ak_ef9
Feb 23, 2007 02:27 PM
Sinner
Jul 14, 2003 09:19 AM
