F22a1 transmission fitment/cross-reference
If you can give a little more background, what are you trying to accomplish?
Also, how skilled are you, as there are more complicated answers but they be more than you would want to tackle.
I have a 92 Accord with an F22A1 engine and a bad tranny. I would like to know what other Hondas have a transmission that will bolt up to my engine
.Manual or automatic trans? There are a lot of manual options that will fit but I'm not sure about using other transmissions given that they are electrically controlled with solenoids etc.
I think with an automatic you will need to get another for the car of around the same years (1990-1993?) as I believe later ones such as the 1998-2001 auto might bolt up but it won't go into overdrive, so you will only have 3 gears. It will run (I just was on another thread where I presume someone hooked it up and didn't realize they were losing a gear, but it runs!).
Might be able to find one in a junkyard, and they sell them on Ebay for about $500 with shipping.
This one says it only has 77k on it.
https://www.ebay.com/b/Complete-Auto.../bn_7083777089
If you are capable of doing anything, then I would rebuild your current transmission if cost is an issue. It might be cheaper. It will take longer than a swap, but cheaper.
I can get one from a pick and pull around here for about a hundred fifty bucks but that's a pick and pull there's two or three to choose from without driving a hundred miles
Pocalude93
Apr 25, 2011 01:13 AM
