Noise after bumps
I am hearing what sounds like a small clank when I hit a bump. I believe it to be only on the driver side front. I am unsure if this is relevant or not, but I get a click or small clank when I brake after changing directions.
I've tried using my weight to press down on the fender to cause the shock to compress up and down but I do not hear the noise coming from doing that.
At one point I replaced my front brake pads and also noticed one of the calipers, I believe to be the opposite of the side I hear the noise come from, I move side to side more so than the other caliper.
Some of this may not be relevant to what I am asking, but I am trying to place as much info as I can, in case it does help lead to a possible answer/idea of what may be causing the noise.
