Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Crank no start?
Old Apr 16, 2021 | 02:43 PM
Tiff Castille's Avatar
Default Crank no start?
04 civic dx, manual transmission, I have replaced so far (myself) valve cover gaskets, passenger/front motor mounts, both CV axles, ac compressor, upstream and downstream 02 sensors, ignition coils, spark plugs, car started "jerking" real hard when accelerating changed camshaft sensor problem solved, 2 days later car dies while driving, would not start after, only made loud whining noise, no ck engine light either, changed timing belt, water pump, put #1 piston at TDC, pulleys all aligned, tired starting, will not start, makes whining noise (I'm assuming the starter) and pulleys are moving, but wont start, throwing code P0118 (engine coolant temperature 1 circuit high) would this cause car not to start?
Old May 13, 2021 | 04:58 PM
letank's Avatar
Default Re: Crank no start?
replace your camshaft sensor, ours went bad after 8 months... if bought to your local parts place, it may have come with lifetime warranty
Beats Bang
29
Mar 26, 2019 10:13 AM
sungajeanne
Dec 23, 2017 04:08 PM
mariposa921
Honda CR-V & Element
Sep 18, 2012 04:31 PM
23sohc
Feb 6, 2009 11:54 AM
DizDitto
16
Oct 9, 2003 10:21 PM
