Suggestions Needed: Unknown oil pressure requirements for eBay Maxingspeed Turbo
Out to Test out a ebaymaxingspeed gt35/30
i just need to know
ehats max psi at wot
max psi at idle on full heat
i just need to know
If you're asking what your max psi of oil pressure is for your engine at the oil feed line, then you'll need to provide the following
Engine model
Size oil feed line,
Oil pressure gauges (If you don't have one.. time to get one)
Are you using any modified oil pumps, or electric pumps?
Oil weight/viscosity used, etc.
There's not much to go on here. I think you bit off more than you can chew.
USDM 4G VTEC
Sep 3, 2003 08:26 PM
