Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Intro/ battery not charging
Old Apr 8, 2021 | 04:36 PM
Jasonstaley81's Avatar
Default Intro/ battery not charging
Hello im jason, own a 2005 Honda civic ex. I'm having some weird charging issues, I've replaced the alternator, the battery, and the eld. Checked both fuses, checked for continuity from alt. Green and white wire, and ecm pin green and white wire was ok. Still not charging. The battery. Looking for ideas please and thank you.
Old Apr 8, 2021 | 04:44 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Intro/ battery not charging
Which fuses did you check?
Old Apr 8, 2021 | 06:17 PM
Fuse #4 10amp under the dash and the 80amp mega fuse under the hood
on a side note I never get any kind of battery or low voltage lights that come o. On the dash
Old Apr 8, 2021 | 06:51 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
With the ignition in the ON position, is there power at alternator plug, terminal no. 1 (Blk/yel wire - blk wire with yellow stripe)? There should be power coming from under-dash Fuse No. 4 with the ignition on.
Old Apr 8, 2021 | 06:54 PM
Yes it shows battery voltage at terminal #1 at alt. Plug black and yellow wire also have voltage at splice packs on top of motor.
Old Apr 9, 2021 | 07:36 PM
Should there be a ground wire coming off from the alternator yo the body somewhere?
Old Apr 11, 2021 | 08:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Nope.
Old Apr 11, 2021 | 08:30 PM
Should the alternator be putting out voltage higher that battery with 4pin connector unplugged, with eng. Running? Or do you have anymore ideas where to look for problems?
Old Apr 11, 2021 | 08:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
See this link for testing the alternator: https://troubleshootmyvehicle.com/ho...e-alternator-1
Your alternator may be charging properly.
If your alternator is charging properly, and the battery gets drained, it may be an issue with car's wires, components, etc. causing excessive parasitic drain.
jethomas
Apr 5, 2013 03:46 AM
Str8JDMCRX
Oct 26, 2010 02:17 PM
NewfieAccordEXR
Feb 4, 2006 07:07 AM
Keith P
Mar 22, 2004 12:59 AM
94TealGSR
Nov 8, 2002 11:36 AM
