new clutch master cylinder....now pedal is weak!!
Well, swapped out my clutch master cylinder today.....and now the pedal is pretty weak. Just doesn't feel the same. The car drives and shifts fine, but the clutch just doesn't 'push' back like it used to. We did our best to bleed the clutch line, but I think we didn't get all the air out.
We just opened up the valve on the slave cylinder on the tranny, and pumped the clutch a few times. I dunno if we did it right though....any input would be welcome
[Modified by SupaTegRS, 2:35 AM 11/17/2002]
[Modified by SupaTegRS, 3:00 AM 11/17/2002]
probably did it wrong
you want to open the valve on the slave cylinder.....depress the clutch pedal.....close the valve....release the pedal........
REPEAT...over and over
if u just pump it with the valve open...ur letting air back in
FLCivic
Jun 30, 2004 03:48 PM
