94 Honda accord leak F22B2 engine
Old Apr 6, 2021 | 11:11 AM
Ty Bullock's Avatar
Default 94 Honda accord leak F22B2 engine
Just installed head gasket. And noticed a leak of oil running down in the pics I provided.
Old Apr 6, 2021 | 02:13 PM
99stockcivic's Avatar
Default Re: 94 Honda accord leak F22B2 engine
insufficient explanation. What is leaking and where and how? What is the question?
Intake leak?
exhaust leak?
oil leak?
gasoline leak?
Old Apr 6, 2021 | 02:34 PM
Ty Bullock's Avatar
[QUOTE=99stockcivic;52391635]insufficient explanation. What is leaking and where and how? What is the question?
Intake leak?
exhaust leak?
oil leak?
gasoline leak?
And yes sorry it's a oil leak.
Old Apr 6, 2021 | 03:20 PM
OK, I give up. If you can't explain it further than the 4 words you wrote, I cannot help you.
So, I will take one stab at one I am guessing you are asking. My guess is you installed a head gasket and it's leaking. If so, then you could have:
installed wrong gasket
installed the wrong one
didn't follow the tightening procedure
bad torque wrench so readings are off
It's not a head gasket issue, something else it wrong.
That's the best I can do if you can't put more detail into what was the original issue, what you did exactly, and what exactly is happening and where.
Good luck.
Old Apr 7, 2021 | 08:01 AM
Ty Bullock's Avatar
Good luck.
Oil is running down the slope
Oil is leaking were the arrows are
Old Apr 7, 2021 | 08:12 AM
Ty Bullock's Avatar
And is this the proper torque for the head bolts. I used a digital torque
Old Apr 7, 2021 | 09:44 AM
Ty Bullock's Avatar
Good luck.
Yes sorry kids and all couldn't get back but I have pics I uploaded and I did get the the gasket from Rock Auto and I did use a electronic torque that connects to the wrench. And it a oil leak
Old Apr 7, 2021 | 11:56 AM
OK, we are making progress.
1 - Was it leaking before you did the head?
2- It appears to be starting near the Distributor, is that right?
If it was leaking before the head gasket replacment, then I would say it's not the head gasket that was leaking, however if you say it was after the head gasket was installed, I would start thinking about else might be touched, such as the VTEC solenoid (if it has one).
If it seems to be coming from the distributor area, then I would check the distributor itself by removing the cap and seeing if there is oil inside.
So, in your own words: 1 when did the leak start and 2 - where does it appear to be starting from?
Old Apr 7, 2021 | 12:52 PM
Ty Bullock's Avatar
When looking at it, it's like it spitting out or splashing. And I will check distributor to see if oil in side but I did look around it to see if so and it a 94 honda accord lx so no VTEC selonid
Old Apr 7, 2021 | 08:10 PM
Ty Bullock's Avatar
Also I can stay before but I read about spot were the transfer case is right we're I am seeing oil
Telecatster
Dec 9, 2012 02:24 PM
n20delslow
22
Oct 31, 2011 10:25 AM
sillyboi
Nov 5, 2010 07:58 AM
Spikes11
Mar 20, 2004 10:34 PM
Mr. Thunderlips
Nov 8, 2002 05:25 PM
